4410 John Deere No Start
   / 4410 John Deere No Start #1
2diamondfarm
West Michigan
TYM 574, Deere 4410, Gehl 353 Mini Ex
My JD 4410 has a problem engaging the starter when the key is turned .
I believe it has something to do with the neutral switch because I have to move the shifter around and find just the right spot while turning the key to get it to engage the
starter
Outside temperature doesn't make a difference .
I have tried by passing the neutral relay in the fuse block with no results.
the seat switch is already by passed . I would like to total bypass the neutral switch if that is possible .
I am open to any ideas
   / 4410 John Deere No Start #2
Bi-passing relay has not effect on the worn neutral switch. You must bi-pass the switch. Having said that,I don't recommend bi-passing any type safety devices unless I know every operator like a brother. There's someone killed or crippled every day as the result of disabled safety devices. Just replace the switch,it might save a life in the future. If neutral switch can't be replaced,bi-pass it but reconnect seat switch to prevent starting from the ground. I KNOW,you never start your tractor from the ground but someone else might. The seat switch is a little help in preventing a child that is climbing on tractor hitting starter.
Thank you for your concern but right now I just need it to start! right now when I need it
   / 4410 John Deere No Start #4
   / 4410 John Deere No Start #6
I think I have found it but it is right up tight to the floor board . I think I will have to remove it to get to it.
Just pull the wire plug and bridge it across the 2 terminals with a piece of wire.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2014 CATERPILLAR...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
Central Machinery 16 Speed Pedestal Drill Press (A59076)
Central Machinery...
