4410 electrical problem
   / 4410 electrical problem
Ok here's what I got. Unless I'm missing something the mfwd switch is OK. However the tractor will start when the mfwd switch is engaged. If it is disengaged turn the key and poof the fuse blows. :banghead::confused3:
I'm really lost now.
PS: With the bulb in place of the fuse, I've wiggled and pulled and I got nothing. Not even a flicker.
   / 4410 electrical problem #12
So the bulb doesn't come on when the mfwd switch is disengaged, and then turn the key on ?
Don't blow another fuse, just let the bulb take the place of the fuse while you check out what is happening.
   / 4410 electrical problem #13
Check the solenoid for MFWD. It may be energized to disengage MFWD.
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
BLANTON 12' DRAG HARROW (A52708)
BLANTON 12' DRAG...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
2016 Fiat 500X AWD Hatchback (A56859)
2016 Fiat 500X AWD...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
AUGER FOR GRAVITY WAGON (A52708)
AUGER FOR GRAVITY...
