4400 preheat?
/ 4400 preheat? #1
790guy
I was talking with my brother the other day and told him how well the 790's preheat works. turning key backwords for 20 seconds. Does the 4400 have a switch operated preheat? he has just started with no preheat and he says it really runs rough.
/ 4400 preheat? #2
from the 4410 Manual:
A-Start Position - Turn the key to the start position to start the engine. Release the key after the engine has started and it will automatically return to the run position. The engine will continue to run.
B-Run Position - Turn the key to the run position and the engine oil pressure light and battery charging lights should illuminate. You will also hear a clicking noise when the engine fuel shut-off solenoid engages. With the key in the run position, push the key in to activate the intake air heater system.
C-Off Position - With the key in the off position, all switched power is off, and the engine should not run.
So, it's there... If he has a 4400, his machine may have a slightly different process. But I'm sure there's some kind od cold weather starting assist.
/ 4400 preheat? #3
He needs to become familiar with his manual. On my 4300, turn the key on, and push in for a few seconds to pre-heat. Makes a world of difference on how well it runs when cold.
/ 4400 preheat?
Thanks Guys! A manual would make a nice holiday present!
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A67714)
PALLET OF 51 X 41...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
NEW HOLLAND 1725 FORD TRACTOR (A65057)
NEW HOLLAND 1725...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
1988 Ford 7610 Series II 4WD 97HP Agricultural Tractor (A66734)
1988 Ford 7610...
2001 MACK VISION DUMP TRUCK (INOPERABLE) (A67714)
2001 MACK VISION...
