That's cause your to close to the flame, raise the loader!!!!!!
Brilliant redneck grilling idea!!!!
I think you need a bigger fire, and need to use butter. Everything is better with butter. Alternatively I would be inclined to use forks and put a a grate between them with some hickory or apple chips on the fire. Then you don't burn the oil in the bucket, and you'll pick up some of the smoke flavor. Be very careful not to get the forks too hot, softening the steel.
I'm with Tinhack. I transport bucket loads of "stuff" when I clean out the neighbors feed lots. I don't really think it would enhance the flavor of the chicken. Besides I DO have a bar-b-q grill.
Peanut oil is the highest "smoke" temp oil,,
Olive oil is the healthiest,,
I simply grill on a wire rack so that neither type of oil is required.
As well, the AC vents on some of the JD tractors will hold a can of beverage and keeps them cool.
Why delete that post? It was a good one! Surely it wasn't perceived as a health hazard to use a tractor bucket as a griddle was it?
Having a post (subject title, image, and verbiage) all removed should not be allowed by TBN.
Pic showed burgers or something cooking in the FEL loader bucket with a fire beneath the bucket. Good wholesome satire, IMO
No indication why it was deleted, as the subject title reads now.
If you have ever roasted marshmallows over a cow patty fire - you to will wonder what makes the mallows brown. We were doing jus fine - till some REDNECK threw some patties on the fire. Doesn't make the smores any tastier either.
Peace - as a rock bucket --may be too closely spaced - unless you are all sand. As a steak bucket - pretty darn fine lookin.
Do I need to tell you what's going to happen right after you have a big bar-b-q using that bucket. You will be moving some dirt, maybe the wife's new flowers, perhaps some gravel. That night you will have every wild animal - West of the Mississippi - digging in your yard. You best figure some way of doing a darn good job of cleaning the bar-b-q bucket.
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2015 Hagie STS 12 Sprayer (A63111)
2015 Hagie STS 12...
