That's cause your to close to the flame, raise the loader!!!!!!
Brilliant redneck grilling idea!!!!
I think you need a bigger fire, and need to use butter. Everything is better with butter. Alternatively I would be inclined to use forks and put a a grate between them with some hickory or apple chips on the fire. Then you don't burn the oil in the bucket, and you'll pick up some of the smoke flavor. Be very careful not to get the forks too hot, softening the steel.
I'm with Tinhack. I transport bucket loads of "stuff" when I clean out the neighbors feed lots. I don't really think it would enhance the flavor of the chicken. Besides I DO have a bar-b-q grill.
Peanut oil is the highest "smoke" temp oil,,
Olive oil is the healthiest,,
I simply grill on a wire rack so that neither type of oil is required.
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2012 TROXELL...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
CFG Industrial MX50R (A60463)
CFG Industrial...
