435 just quit
/ 435 just quit #1
WishinIwasFishin
currently a FarmTrac 435
Hi there....I have a 2005 Farmtrac 435 that was my dads.It has 300 hours on it and up till now has been trouble free.I use this tractor to cut grass using a grooming mower.Last week i was cutting and the tractor sputtered and came right back.About 2 minutes later it sputtered again and quit.It started right back up and quit again and would not refire.Turned over great just wouldnt catch.Fuel level was ok..Cracked each injector and had fuel.it was not overheated either.Any ideas? At least point me in the right direction...Thanks so much
/ 435 just quit
about 100 hours ago....I just assumed that since I had fuel at the injectors they were OK....I will get 2 new ones at NAPA tomorrow and try that.....Thank u
/ 435 just quit #4
There is probably a strainer in the fuel tank also. When you remove the fuel filters open the tank valve and see if the fuel freely flows out. If not, the tank strainer is plugged.
