4310 tilt meter
/ 4310 tilt meter #1
Twanger
KCMO
4310 4wd ehydro 420 loader asof 4/2/02
I have my tilt meter and have a fairly good sloop to my yard. I have already moved my turfs to the wide position in the back not the front. What is the greatest tilt I can safely operate at? Is putting the fronts at the wider stance going to help much? Should I get wheel weights? Does the 420 loader make the tractor have a higher center of gravity?
/ 4310 tilt meter #2
I have a 4400 with a tiltmeter and I mow the back of my dam side to side, and have seen the meter at over 25. Anything over 20 and I am puckered, but I mow very slow at these steeper angles. The FEL has never been off my tractor. When mowing I keep the bucket low. There are other threads on this where everyone agrees that up to 15 is safe, but caution about dropping a wheel into a depression. My biggest concern is that I will get too comfortable at steep angles and loose my caution. My front wheels are at there max. width, the rears where not turned. I do have all tires filled with water and never lift the mower or bucket when on a steep incline. Hope this helps.
/ 4310 tilt meter #3
Twanger,
If you have something heavy for the 3pt hitch....I'd use it too and keep it low. When I mow the banks of our pond (lengthwise) I add my roughly 350lb brushhog and it really helps to keep everything grounded. I've tried it briefly without the loader and the hog and it is a scary propositon. Also, if you happen to have some loose material around (dirt), take a scoop. That'll help as well.
Wear your seatbelt too!
Jim
/ 4310 tilt meter
Thanks guys. It looks like I need to get wheel weights or fill the tires. I will also flip the front tires out.
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A61574)
19ft Sailboat w/...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
1774 (A64280)
1774 (A64280)
2021 JOHN DEERE 17G EXCAVATOR (A64279)
2021 JOHN DEERE...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
