4310 power enough
/ 4310 power enough #1
mscheer772
Hayward Wisconsin
4310 JD 2003
Does the 4310 have enough power to pull a 7 foot chisel plow with a landscape rake attached.
/ 4310 power enough #2
Welcome to the forum.
Does it have the power? Sure, depending on how deep and how fast you go and what the soil is like. At some point though, you will run out of power. Now that is not a very good answer, granted, but as close as I could come. /forums/images/graemlins/wink.gif
I have the JD4300 and am pleased with the power it has, although would like a bit more (always need more power). /forums/images/graemlins/tongue.gif
/ 4310 power enough #3
7 foot chisel plow
<ul type="square"> [*] It is normally pulled at 4 mph and requires 10 hp per shank and good tire traction to operate it. Shanks are spaced 12" apart
[/list]
If this is the same thing, no.
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2005 Ford F-350 Crew Cab Pickup Truck (A61573)
2005 Ford F-350...
8in Channel Tooth Bucket Mini Excavator Attachment (A61572)
8in Channel Tooth...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2005 Butler pole trailer (A62679)
2005 Butler pole...
