4310 Broke
/ 4310 Broke #11
I am sorry this happened to your tractor.........I agree with "gkk2001"
on the rear mower thing.....I have had too many headaches with MMM(s)
to own one again......I have been converted to the wonders of rear-mount
mowers......they are far easier to work on and get access to ....
Just be careful when mowing around decks /forums/images/graemlins/grin.gif
Good luck on getting your tractor fixed !
/ 4310 Broke #12
<font color="blue"> Just be careful when mowing around decks </font>
And trees and fences and cars and landscaping and gardens and buildings and.........
Just to give the other side of the story for those readers who make choices based on the information posted here, I've had a MMM for 15 years with absolutely no headaches. It tracks right where the front tires are going. All my mowing is done looking forward (except when I'm backing up). /forums/images/graemlins/smile.gif
/ 4310 Broke #13
....that is very true.....I have 2.1 wide-open acres with some nasty bushes
in a couple of spots that I like to back the rear-mount into to cut the grass under them and I do not ended up bleeding from limb lashing /forums/images/graemlins/grin.gif
/ 4310 Broke #14
I am curious, did the transmission break underneath the tractor? I once had a rockshaft housing explode!! Same thing, hydraulic fluid all over me, everything!! I inspected it closely and could not belive it was made of lightwieght cast material. A friend, who works for another JD dealer said it was due to improper assembly of the rockshaft valve and improper adjustment. In a round about way, my local dealer made me feel it was my fault, although they just installed a new rockshaft valve. It was repaired "no charge" but it made for some really heavy duty stress. I am sorry, but my belief is that these machines are designed in such a way, they cannot tolerate any, "ANY" error at all. And I feel this is shameful, its difficult to go out and do any sizeable job without making at least some degree of error, actually, on a massey or other equivelent machine, it would not even be considered an error. Its only considered an error when you surpass the machines TOLERENCE, and on this particular model, that is not much "TOLERENCE". I am not trying to worry or scare you, but be extremely careful, and I would defenitely opt for the extended warranty as soon as possible, as the longer you wait, the more expensive it gets. gott
/ 4310 Broke
I have to admit that I am not very mechanically inclined. I do very little work on my own vehicles (starters, alternators and brakes are about it). So, I am baffled as to the cause of this. I don't think the transmission broke if you are talking about the guts of the thing. But I also didn't spend a lot of time checking the tractor out. I knew it was something that I could fix and I figured the less I touch it the better. I was also pretty much devastated and trying to figure out how I was going to get all the hydraulic fluid off of my new drive and new garage floor. What a mess! Although the 160 pounds of oil dry did a pretty good job. I do have a stain on the drive but I am hoping it fades over time.
I did speak to the service man at the dealer I used. He said they did not find any missing pins, but will put the deck back on to make sure everything works okay before I get the tractor back. It may be my lack of mechanical knowledge, but I am amazed that the case broke unless there was a defect in the casting, even if my deck was out of adjustment, which seems to be the theory. I would have thought that there would be some sort of bypass or limit on the hydraulics or you could be breaking things all the time. As I said, I am no mechanic and this is my first tractor, so I could be way off base. My biggest concern is that this doesn't happen again.
Overall, I love the tractor and am less pleased with the dealer because of other experiences I have had since I bought the tractor. I took a month longer than I was told to have the tractor delivered when I purchased it because they had to wait on a loader, then had the wrong brackets for the mower. I was told they would show me how to take the loader on and off, work the mower etc... on delivery but the delivery man had no clue how to operate the tractor and couldn't show me anything. The mid PTO did not when I first got the tractor because a wire was unplugged. It was clear to me that they had not gone over the tractor before they delivered. When I had the 50 hour service done, I had to take it back to the dealer a second time to have the transmission fluid changed because the service man didn't realize it was a hydro. He also had to replace an O-ring under the seat and fix the tilt steering wheel on the 2nd visit, which I don't consider to be the fault of the dealer or JD, but just a defect or faulty part, which can happen with anything. I also referred a co-worker to them for a 300 series mower, right after I bought mine and they did not have a good experience. Individually, none of these things would bother me, but collectively, I have been irritated at times. I might use this dealer again in the future because I think some of the problems I have experienced are just flukes and once I get the tractor back, I will be reminded of how much I like it and why I chose the 4310 over other makes that I looked at.
/ 4310 Broke #16
I sure hope they jump on it for ya. Its a total bummer when er just getting warmed up and something like that happens. Best of everything,,,gottt
iDrive TDS-2010H...
AGT Industrial M-DGR (A60463)
AGT Industrial...
2025 Kubota KX040-5 (A60462)
2025 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
ATTENTION PLEASE READ (A60463)
ATTENTION PLEASE...
Takeuchi TL12R2 (A60462)
Takeuchi TL12R2...
