4310 3rd scv installation instructions
/ 4310 3rd scv installation instructions #1
csnow
Fredericktown
JD 4310
Was wondering if anyone had the instructions for this. I bought a partial kit and pieced the rest together but I have no instructions. I have a general idea from reading post and looking at pictures what needs to happen but I was wanting to make sure I had everything covered. I also ordered a power beyond kit for it too to install at the same time. Thanks in advance.
/ 4310 3rd scv installation instructions #2
Likely be similar to adding the 3rd SCV to my 4300.
Maybe lay out your parts and post good pics. Then we likely can give you pointers as to where the parts you have and have pieced together will go, and how to go about getting them there.
I see three similar threads for adding the 3rd SCV to 4310's, but have not reviewed them.. maybe you have already.
/ 4310 3rd scv installation instructions #3
Here are the instructions I found. Hope this helps.
  • 4310 third scv.pdf
/ 4310 3rd scv installation instructions #4
If you know the kit P/N; it should start with LVB? Your local JD service department can print out install instructions for you. These should also include a parts list.
Thanks for all the help guys, just got the kit and power beyond kit installed today,.
/ 4310 3rd scv installation instructions #6
csnow
Can you tell us how the install went for you? Hope ok.
Did see another thread you started about a leak. Hope that goes well..
Went pretty well, hardest part was the control lever getting it wiggled into place then installing the pins and cotter keys. Didn't realize I needed to remove one of the other hydraulic lines on the valve to get the new line in place and I went ahead and installed one of the new o-rings out of the kit on the line I removed so I wouldn't have to worry about a leak down there. then I noticed that one of the adapter fittings came with both o-rings so I lucked out there. power beyond kit was easy as well.
