4310-3720 wheels
/ 4310-3720 wheels #1
Havoctec
Minnesota
John Deere 4310
Does anyone happen to know if I can swap R4's with rims from a 4310 with turfs and rims from a 3720?
/ 4310-3720 wheels #2
Don't know, I have a 4310 with r-4's this is what's stamped on the rim. Maybe a JD dealer's parts dept question.
JB.
/ 4310-3720 wheels #3
The wheels may physically bolt on, i think
the bolt patterns are the same.
what may be different, is the tire sizing.
i believe that JD changed tire sizes along with
their MFWD gear ratio, which would make older
tire sizes not compatable with the MFWD.
it is certainly worth confirming before going forth.
/ 4310-3720 wheels #4
I would suspect that you can, but check first.
Look at the spec sheets for each tractor, and possibly be able to compare the tire/rim sizes of each.
My impression when planning to switch up to the 3720 was they were the same. Was even planning to take my solid ROPS off the 4300 and switch it with the foldable ROPS on the 3720. Didn't trade up.
Edit
Just compared the 4310 with the 3720, and both specs list the same turf and R-4 tire sizes.
Turf 41x14-20, and R-4 as 15-19.5
/ 4310-3720 wheels #5
Did they change the size on the 4310 some where along the way, Look at the picture of mine, not sure but I assume that is the size?
19.5X 13.00 That's stamped on my R-4's rim.
Just curious :)
JB
/ 4310-3720 wheels #6
I was thinking that might be a rim designation, rather than the tire. Others may know for sure.
What is on the sidewall of the tire?
/ 4310-3720 wheels #7
Good question, I'll have to check tomorrow.
/ 4310-3720 wheels #8
Yeah, that's the wheel size....your tires are 15" wide or 19.5-15 R4s.
That's what I have on my 4300, too. I suspect that the 3x20s are
the same, but I don't know for sure.
/ 4310-3720 wheels #9
Just checked mine and they are 15's, never paid attention to the tire size even when getting chains, since I custom made mine from surplus.
JB.
/ 4310-3720 wheels #10
I kept my turf specials from my former 4310 for my 3520. Well the fronts went on with no issue but the Rears have a different bolt pattern so I had to buy a new set of rear wheels to make it work. No issues with the tire size.
/ 4310-3720 wheels #11
If the bolt patterns are different, that sure answers the OP question....can't be done.
/ 4310-3720 wheels
Thanks guys. That is what I was looking for. One would think it would be cheaper to stay with the same tire and rim. Oh well.
One more reason for me to deside not to move to the 3720 a friend of mine is selling. Cost being number one since our 4310 does everytning we want.
/ 4310-3720 wheels #13
Havoctec
I've been pretty much in the same boat, making the same decision. Was seriously thinking of trading up (4300 to 3720) for more hp. But the one piece hood on the 3720 was a negative, as well as the foldable ROPS. Also, I didn't think the sloping hood gave any more visibility over the 4300.
As well, the 4300 still does everything I want, and I can get along with the hp it has.
Didn't know about the wheel change, and that surprises me as well. But change is what makes old tractors obsolete, and new ones more unique. Engineers have to account for their progress and worth too.
/ 4310-3720 wheels #14
I almost tilted myself because of that but that cab did it for me. The switchover added a cost of about 500 bucks. which by coincidence is $220 less than i paid for all 4 wheels and tires (slightly used) Now i have an extra set of wheels for a 4310 and no 4310;)
Oh well, I guess i can use them for paper weights. Along with the Betst Rear mower :rolleyes:
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
Invoices (A65640)
Invoices (A65640)
2022 EZ-GO ELITE...
Troy-Bilt Pony Riding Mower (A65579)
Troy-Bilt Pony...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2022 EZ-GO ELITE...
