4300 Sync Reverser Transmission
/ 4300 Sync Reverser Transmission #1
Mike_H
My 4300 sync reverser has developed a problem with the low range shifter (1-4) not staying locked in gear. All the gears work fine if you hold the shift lever in place but when you let go it may go for a little while and then it jumps out of gear and into neutral. From what I have found out so far there seem to be some spring loaded detents which hold the actuator in a certain gear. Does anyone have any experience with this and know whether it may be possible to attempt a repair myself?
/ 4300 Sync Reverser Transmission #2
I can't remember this specific gear shift. Is there a turnbuckle or threaded adjustment rod?
/ 4300 Sync Reverser Transmission #3
I was looking at one of these used and my dealer advised me against one because of this same issue.
SCHEDULE 80 PIPING ON PALLET (A67714)
SCHEDULE 80 PIPING...
2009 POLAR TANK TRAILER (A67714)
2009 POLAR TANK...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
2016 CHVEROLET SILVERADO PICK UP TRUCK (A66091)
2016 CHVEROLET...
2025 Auger with Bits Mini Excavator Attachment (A66734)
2025 Auger with...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
