4300 Sync Reverser Transmission
/ 4300 Sync Reverser Transmission #1
Mike_H
My 4300 sync reverser has developed a problem with the low range shifter (1-4) not staying locked in gear. All the gears work fine if you hold the shift lever in place but when you let go it may go for a little while and then it jumps out of gear and into neutral. From what I have found out so far there seem to be some spring loaded detents which hold the actuator in a certain gear. Does anyone have any experience with this and know whether it may be possible to attempt a repair myself?
/ 4300 Sync Reverser Transmission #2
I can't remember this specific gear shift. Is there a turnbuckle or threaded adjustment rod?
/ 4300 Sync Reverser Transmission #3
I was looking at one of these used and my dealer advised me against one because of this same issue.
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65056)
2013 VOLVO A40F...
2007 KENWORTH (INOPERABLE) T880 (A67714)
2007 KENWORTH...
2007 STERLING LT7500 SERIES CRANE TRUCK (A67714)
2007 STERLING...
Unused 2023 Unused Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
Unused 2023 Unused...
