4300 rear diff lock
/ 4300 rear diff lock #1
Trev
Platinum Member
Williamson, NY (near Rochester)
Currently tractor-less
I wonder if I'm doing something wrong. I just used my front blade to cut a path for my wife out to the garden. 4wd engaged, and pushing as much as I could. When it would start spinning, I'd raise the blade a tiny bit to get moving again, and then feather it back down. During all of this, I was trying to get the rear diff to lock. It would occassionally go in, and then pop right back out again. Finally I just kept my heel on it to keep it engaged, since I was just going in a straight line I figured this wouldn't hurt it. But why is it so hard to get it to engage? It normally engages about 1 out of 10 times when I want it.. is this normal?
Thanks,
Bob
/ 4300 rear diff lock #2
Trev Normal
The diff. lock engages when and as you hold your foot on the foot lever. It disengages when you release your foot (sometimes it will stay engaged if there is a lot of pressure on the gears, in my opinion. But it releases as soon as the pressure on the gears releases and your foot is off the foot lever).
So it seems to me it is working properly, and you don't have to worry about something being wrong.
/ 4300 rear diff lock #3
<font color=blue>"is this normal?"</font color=blue>
Yes. My 4200 works exactly the same way and, according to my owner's manual, that's the way it should work. /w3tcompact/icons/smile.gif
/ 4300 rear diff lock #4
I would be worried if it stayed engaged when you took your foot off the pedal. On all the tractors I have used, it only engages when you keep your foot on the pedal.
I actually rarely use the diff lock; I've found that when a wheel starts to spin, lightly pressing on that wheel's break until it stops spinning often works just as well, and is more convenient since I am usually on the foot throttle anyway.
<font color=blue>
I actually rarely use the diff lock; I've found that when a wheel starts to spin, lightly pressing on that wheel's break until it stops spinning often works just as well, and is more convenient since I am usually on the foot throttle anyway. </font color=blue>
Wouldn't work for me, if using the foot throttle, because I have a gear tranny and the brakes are on the right along with the throttle. /w3tcompact/icons/smile.gif But I might try this while using the hand throttle, which I usually do when pushing heavy dirt.. I use the foot throttle when doing lots of back and forth movement like carrying loads of dirt someplace.
Thanks for the feedback guys.. sounds like things are as they should be. It just seemed odd that the lock was so reluctant to lock even with a rear wheel spinning. I really don't need it often, but I do wish I was easier to get it to engage when I do need it. Oh well.. life isn't perfect. /w3tcompact/icons/smile.gif
/ 4300 rear diff lock #6
<font color=blue>It just seemed odd that the lock was so reluctant to lock even with a rear wheel spinning.<font color=black>
Trev
I don't think anyone said it should be engaged when a rear wheel was spinning. The manual says; to prevent damage, it is important that the lock should not be engaged when one wheel is spinning and the other is not.
You could be doing damage to your lock, and if it is acting funny, then maybe some damage has already been done. I hope not.
Check out the manual, as the information is there.
<font color=blue>
I don't think anyone said it should be engaged when a rear wheel was spinning. The manual says; to prevent damage, it is important that the lock should not be engaged when one wheel is spinning and the other is not. </font color=blue>
Yes, but it absolutely will not engage in other situations. I've tried pushing in the clutch, and it won't engage. I've tried it in various situations, and the only time it will engage is if one of the rear wheels is spinning a bit. This has been its behavior since it was new. Think it's messed up? Note that usually I still have some forward motion, so it isn't a case of "one wheel is spinning and the other is not." But one is clearly spinning (i.e., losing traction), and the other is moving but only because, I surmise, the front wheels are still pulling and the tractor is still moving.
/ 4300 rear diff lock #8
I assume you are to stop the wheels from spinning, (push in the clutch), then step on the diff. lock to engage, and hold it in that position as you let out the clutch. I would expect it to then lock the two rear axles together and you will feel them lock as it happens. Is that workable for you? That is how mine works, albeit I have the HST rather than gear. Wish you the best.
<font color=blue>
I assume you are to stop the wheels from spinning, (push in the clutch), then step on the diff. lock to engage, and hold it in that position as you let out the clutch. I would expect it to then lock the two rear axles together and you will feel them lock as it happens. Is that workable for you?</font color=blue>
I have tried pushing and releasing the clutch while pushing down on the diff lock, but I'm not sure I've ever pushed the clutch, then the diff lock, then released the clutch. Thanks! I'll give it a shot next time out...
Bob
Bob
/ 4300 rear diff lock #10
Bob,
Thats the only way the diff lock on my Yanmar will engage. I think the US manual I have cautions against trying to engage while the tire is spinning.
When one spins, I push in the clutch, step on the diff lock, and release the clutch. When the wheel starts to spin, the diff lock pedal drops and engages.
Jerry
/ 4300 rear diff lock #11
It sounds like you are using the differential lock correctly. The differential lock will only engage when one wheel is turning faster than the other is how it should work. The reason for this is you have a sliding coupler inside the rear end of the tractor that must line up with the other part of the coupler before it will engage and the only way to make them line up is one wheel must be turning a little faster. Every now and then you will get lucky and they will be lined up with each other without one tire needing to turn faster but not often. The only thing that you should not do is never engage the differential lock with one tire spinning out of control. The next time you are doing a little blade work and you feel it start to loose traction, just lightly press the differential peddle down untill the sliding coupler lines up and keep it engaged until you do not need it any longer. Also it is a good idea to lubricate all of the differential lock parts that go into the rear end housing including the differential lock linkage at least a couple times a year because I have seen several that have seized up over the years.
/ 4300 rear diff lock #12
Trev,
Beenthere is correct. You need to have both wheels stopped. Press on the differential lock. Ease out on the clutch. As you do this the lock should engage. You do not want a wheel to be spinning as you engage it. If a wheel is spinning, you then risk breaking a tooth or other parts.
/ 4300 rear diff lock #13
The diff lock is only to get you thru a tuff spot and not to be engaged like a "Detroit Locker" ... once the wheels are not slipping the Diff Lock jumps out .... when I was a much younger man ( a very distant memory) I recall breaking ground all day long with the front wheels spenting most of the day in the air making me stear with the brakes ... what's the saying "God looks after fools and drunks (and young kid tractor drivers)"
Okay, folks.. it seems like we have two different opinions being expressed here:
1) Wheels should be completely stopped when engaging diff lock.
2) One wheel must be spinning to some extent for it to engage.
All my manual says is to "stop or slow tractor before engaging." Which doesn't really illuminate the problem much except it seems to suggest that it is okay to be moving when engaging it.
I tried what some folks suggested about pushing in the clutch, pushing down the lock pedal, and then easing out the clutch. The diff lock pedal would not go down. I tried this repeatedly.
So then I tried doing some dirt pushing, slowly, and just gently rested my heel on the lock pedal. Every now and then it would engage, and it made a noticeable difference in traction. I would have to keep my heel on it most of the time to keep it engaged, but I gather that's normal.
What may or may not be normal is the inability to engage it when the tractor is stopped with the clutch depressed. I guess it's okay the way it is, but I often can't get it in when I want it in.. maybe I just have to live with that?
Thanks everyone,
Bob
/ 4300 rear diff lock #15
Seems safe to tell you that your differential lock seems to be working correctly. You will learn how to effectively engage it with practice. Hopefully you won't have a big torque load differential when the pins engage that is sufficient to cause a failure.
With my tractor in 4wd, I rarely have to engage mine. If there isn't enough traction without the diff. lock engaged, I take a smaller bite. Have fun.
/ 4300 rear diff lock #16
It is made to be engaged while moving and we have done this for over 20 years with not any problems on small and large tractors. It is designed so that if you are, lets say plowing for example, you don't have to stop, just simply engage it when you can tell you are beginng to loose traction. The other way of stopping such as in plowing would be a big hassle.
1. You would have to stop
2. Raise plow
3. Back up a little
4.Let out clutch and start moving forward while pushing down on differential lock peddle.
5. Quickly lower plow back into ground.
Actually the same thing is basically happening when people are releasing the clutch and trying to engage peddle. When one will starts the movement it will actually do just a little bit of will slippage for a split second or two that most people do not realize. Sometimes this little movemet will be enough so that the sliding coupler will line up but not always. Their is also several different brands and sizes of tractors out their with the same type of differential lock setup, except the cluch and differential lock peddle are both located on the same side. This would make it almost impossible to let out the clutch and engage the differentail lock at the same time without getting help from your other leg.
The main concern is do not engage the lock like others have said before, while one tire is spinning out of control.
/ 4300 rear diff lock #17
Sitting still is OK but may be difficult because the gears may not be lighned up. Pushing in the clutch really doesn't help in that situation. Slight motion is OK as well. The only thing not to do is engage it while one wheel is spinning rapidly. If your tractor's a gear unit, I'd suggest pushing in the clutch slightly, if a hydro, let up mostly on the pedal. Common sense dictates that you don't want to "shock" the drivetrain.
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Skid Steer Post Auger (A65640)
Skid Steer Post...
2014 Bobcat E63 (A64126)
2014 Bobcat E63...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
More info coming soon (A61569)
More info coming...
Unverferth Lift Assist Wheels (A65640)
Unverferth Lift...
