4300 needs weight
/ 4300 needs weight #11
Rick
>>I don't understand why the equipment manufacturers can't produce a table or chart estimating additional rear weight required<<
I can't speak for all equipment manufacturers but the owners manual that came with my JD430 FEL specifies exactly how much rear weight is required. I assume generic, aftermarket FEL manufacturers can't do that because they don't know what brand/model tractor their FELs are going to be mounted on?
Chuck in IN
/ 4300 needs weight #12
My N.H. loader manual gives all the counterbalance info I need for the specific application. I tend to agree w/Chuck about the aftermarket ones,maybe someone else could shed some light on aftermarket loaders and manual info.Tom
/ 4300 needs weight
Well I have a GB Loader and the manual said refer to the tractors owners manual for proper rear ballast, I can't find that inhfo in the 4300 manual, unless I've over looked it.
I sould need the same weight that a 430 loader would need. The GB is alittle heaver and will pick up 1450 LBS at full height, just alittle more than the 430 JD loader.
/ 4300 needs weight #14
DDT
The info isn't in the 4300 manual it's in the 430 FEL manual #OMW44980 F8 PAGE 10-10. It says to use liquid ballast in rear tires plus 1320 lbs on 3ph.
It also says the following in bold font:
CAUTION: To help prevent the possibility of
personal injury or death caused by
tractor/loader roll over, DO NOT operate
tractor/loader unless it is equipped with proper
ballast.
Chuck in IN
/ 4300 needs weight
rekees,
Thanks for the weight on the rear, about how much weight is in the tires, I'll bet I can call my goodyear tire man tell him the size of the tire and how full the manual said it to be and he can give me a exact weight per side. I all ways use rear equipment for weight. I just as soon add enough weight to the box blade one time and be done, instead of trial and eror.
I want to build a concrete 3 point ballaslt but it's got to be big enough to be heavy enough.
Thanks DDT
/ 4300 needs weight #16
DDT
>>about how much weight is in the tires<<
Sorry, but the 430 manual doesn't say or imply how much weight is in the tires. Best bet would be to call the Goodyear man for an estimate.
Somebody posted a pic here at TBN of a homemade concrete ballast 3ph. I've also seen estimates of how much concrete it would take to achieve a given weight. You might wanna do a search and see if you can find those posts. Think the 3ph on a 4300 will lift a ton so that shouldn't be a limitation. Good luck with your FEL and ballast.
Chuck in IN
/ 4300 needs weight
Well I called my tire man. He didn't have the tire size in his book so he is guessing at 350LBS to 370LBS each tire at 75% full (valve stem). I will figure 700LBS + 1320LBS =2020LBS, a ton sould be close enough.
Now how many cu ft of concrete adds up to 2K LBS?
my first guess was 800 to 1000, I was only half way there!
Thanks Guys
/ 4300 needs weight #19
DDT,
This thread will give you the weights of concrete mix. According to the info the average weight of concrete with a gravel aggregate is 150 lbs per cubic foot. At that weight 13.5 cu. ft. would be 2025 lbs.
DFB
/ 4300 needs weight
Thanks for the info. I'll buid a box 25"x25"x36"=13cu ft=1953lbs, then add alittle for steel and I'm there. Thanks
2015 Ford Transit 150 Cargo Van (A59230)
2015 Ford Transit...
2004 Ford F-450 4x4 Venturo ET18KX 2 Ton Crane Service Truck (A59230)
2004 Ford F-450...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
(INOP) 1996 FORD F150 SINGLE CAB TRUCK (A59823)
(INOP) 1996 FORD...
2023 Dodge Durango SUV (A59231)
2023 Dodge Durango...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
