4300 needs weight
/ 4300 needs weight #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I got a chance to try my new GB loader today. I got to move about 10 ton of very wet rock to a drive way. I had my king kutter box blade on, it only weighs 435 LBS and no liquid in the tires (becauces of mowing dutys) This B Blade was enough for the 855 but not the 4300. I think I will add a bar to hold some suit case weights off of a farm tractor. If I add 4- 96 lbs weights with my b blade then I should have close to 800 lbs on the rear, The way she acted this may not be enough total weight either. Any thoughs about total LBS of rear weight. Thanks for every ones insight/ experience. DDT
/ 4300 needs weight #2
DDT,
I have my tires filled and I have 600 pounds of weight on my tires with a 6 ft. woods box blade on the back. With that I can lift 1600-2000 pound round bales with the loader. The only time it gets tipsy is when I lift it way up to put them in the round bale feeders. Other than that I never have a problem.
/ 4300 needs weight #3
Dana,
I don't know if this helps, but it seems to me that the amount of rear weight should IDEALLY equal the amount of front weight.../w3tcompact/icons/shocked.gif
I'm thinking here that a tractor is usually pretty well balanced front to back, without anything on the 3PT or anything in the FEL bucket. Of course, it's sometimes hard to figure what a full bucket weighs, /w3tcompact/icons/blush.gif but I called a local material yard, and they gave me some numbers (tons per yard) for some various types of materials, and they seemed pretty accurate. /w3tcompact/icons/cool.gif Of course, the practical use of that is to insure that one has ENOUGH weight to balance out their tractor - I don't plan on dumping sand out of my weight box! /w3tcompact/icons/laugh.gif
I dunno - any other thoughts/notions/ideas/suggestions ?
Dave Wells
/ 4300 needs weight #4
DDT
My rear tire on my 4300 are filled andthe tractor is a little light in the front with the b/h on. The tractor is very stable but there isn't much weight on the bucket for digging. The tractor does very well with nothing on the back but it's a little light in the back-not much just a little. Also with nothing on the back the front tires really squat with the loader full. In my case I think about 3-400 pounds on the 3ph would be about perfect along with the filled tires(don't know how much weight is in them so I can't tell you how much tatal weight that would be).
Jerry
/ 4300 needs weight #5
>>I'm thinking here that a tractor is usually pretty well balanced front to back, without anything on the 3PT or anything in the FEL bucket.<<
Dave your thinking is VERY dangerous. The weight of an empty FEL bucket (without corresponding weight in the rear) is enough on a 4300 to cause lose of rear wheel traction and therefore a runaway tractor without any braking. This can happen going downhill. I speak from personal experience.
Chuck in IN
/ 4300 needs weight #6
Dave,
Balanced without anything attached to the front or rear, yes, but balanced without anything in the FEL? No. The weight of the FEL alone will throw the F/R weight distribution way off. With a loaded bucket (gravel, sand, etc), you might need about 800-1,000lbs on the back of a 4300 to counter-balance the load. Even without a load in the bucket, without a counter-balance of some kind (250, 400lbs minimum I'd say, if there were to be no additional load on the front) you could easily get the tractor to be unstable... there are always changing ground conditions, etc. I wouldn't ever do much without some counter-balance.
/ 4300 needs weight #7
Chuck & Muhammad,
Thanks for your input. I admit to total ignorance about anything other than my own JD4100Hydro. Mine does seem pretty well balanced with JUST the FEL & smallest bucket (54" or 60", not sure), but if I take the bucket off and put the pallet forks on I can tell the difference - the frame & forks must weigh over 200 lbs, while the bucket itself probably weighs less that 100.
I NEVER use either the bucket or pallet forks without the ballast box. Fortunately I learned that lesson the first time I felt the rear end go up . . . /w3tcompact/icons/shocked.gif
Thanks again for pointing that out - it's very easy to assume something that doesn't apply in your situation. /w3tcompact/icons/blush.gif
Dave Wells
/ 4300 needs weight #8
<font color=blue>I NEVER use either the bucket or pallet forks without the ballast box.</font color=blue>
Good idea. /w3tcompact/icons/smile.gif Just always keep safety in mind. I have heard from others with tractors similar in size to the 4100 warning others of stability issues with no rear ballast, even with just the FEL installed... But of course, as the operator, you know more about the way the tractor handles/feels than others.
/ 4300 needs weight #9
DDT,
Don't think only of moving dirt,gravel etc.. w/your FEL w/no weight on the back,for if your transporting good size rock or rocks w/your FEL on a side slope or going down the slope,and the rock or rocks sides in your bucket you may end up for a ride do to no traction on the rear tires.
Thomas..NH /w3tcompact/icons/wink.gif
/ 4300 needs weight #10
It appears that this question has been brought up numerous times. I don't understand why the equipment manufacturers can't produce a table or chart estimating additional rear weight required for lifting various loads on different grades. It appears that this method would be much safer than trial and hope. Maybe this process explains why the farming industry leads other industries in accidents.
Thanks,
Rick
<P ID="edit"><FONT SIZE=-1>Edited by vtrick on 02/28/01 03:56 AM (server time).</FONT></P>
/ 4300 needs weight #11
Rick
>>I don't understand why the equipment manufacturers can't produce a table or chart estimating additional rear weight required<<
I can't speak for all equipment manufacturers but the owners manual that came with my JD430 FEL specifies exactly how much rear weight is required. I assume generic, aftermarket FEL manufacturers can't do that because they don't know what brand/model tractor their FELs are going to be mounted on?
Chuck in IN
/ 4300 needs weight #12
My N.H. loader manual gives all the counterbalance info I need for the specific application. I tend to agree w/Chuck about the aftermarket ones,maybe someone else could shed some light on aftermarket loaders and manual info.Tom
/ 4300 needs weight
Well I have a GB Loader and the manual said refer to the tractors owners manual for proper rear ballast, I can't find that inhfo in the 4300 manual, unless I've over looked it.
I sould need the same weight that a 430 loader would need. The GB is alittle heaver and will pick up 1450 LBS at full height, just alittle more than the 430 JD loader.
/ 4300 needs weight #14
DDT
The info isn't in the 4300 manual it's in the 430 FEL manual #OMW44980 F8 PAGE 10-10. It says to use liquid ballast in rear tires plus 1320 lbs on 3ph.
It also says the following in bold font:
CAUTION: To help prevent the possibility of
personal injury or death caused by
tractor/loader roll over, DO NOT operate
tractor/loader unless it is equipped with proper
ballast.
Chuck in IN
/ 4300 needs weight
rekees,
Thanks for the weight on the rear, about how much weight is in the tires, I'll bet I can call my goodyear tire man tell him the size of the tire and how full the manual said it to be and he can give me a exact weight per side. I all ways use rear equipment for weight. I just as soon add enough weight to the box blade one time and be done, instead of trial and eror.
I want to build a concrete 3 point ballaslt but it's got to be big enough to be heavy enough.
Thanks DDT
/ 4300 needs weight #16
DDT
>>about how much weight is in the tires<<
Sorry, but the 430 manual doesn't say or imply how much weight is in the tires. Best bet would be to call the Goodyear man for an estimate.
Somebody posted a pic here at TBN of a homemade concrete ballast 3ph. I've also seen estimates of how much concrete it would take to achieve a given weight. You might wanna do a search and see if you can find those posts. Think the 3ph on a 4300 will lift a ton so that shouldn't be a limitation. Good luck with your FEL and ballast.
Chuck in IN
/ 4300 needs weight
Well I called my tire man. He didn't have the tire size in his book so he is guessing at 350LBS to 370LBS each tire at 75% full (valve stem). I will figure 700LBS + 1320LBS =2020LBS, a ton sould be close enough.
Now how many cu ft of concrete adds up to 2K LBS?
my first guess was 800 to 1000, I was only half way there!
Thanks Guys
/ 4300 needs weight #19
DDT,
This thread will give you the weights of concrete mix. According to the info the average weight of concrete with a gravel aggregate is 150 lbs per cubic foot. At that weight 13.5 cu. ft. would be 2025 lbs.
DFB
/ 4300 needs weight
Thanks for the info. I'll buid a box 25"x25"x36"=13cu ft=1953lbs, then add alittle for steel and I'm there. Thanks
Patterson water pump (A59230)
Patterson water...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
Pallet Forks (A64127)
Chery 21'x24' Double Carport (A64127)
Chery 21'x24'...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
