4300 hst problem
/ 4300 hst problem #1
liftdd2
john deere 4300
I have a 4300 with a hst. I recently split it to reseal the front pump that is driven by the engine. Now when I push the forward pedal it moves in reverse. What did I put in backwards? Thank you
/ 4300 hst problem #2
Try switching the plugs on the pedal potentiometers.
/ 4300 hst problem
Thank you. I will try that. I really don’t want to take it back apart.
/ 4300 hst problem
I only have one switch on the forward pedal. Anyone have any idea if I installed anything backwards?
/ 4300 hst problem #5
liftdd2
Did you follow the service tech manual procedure?
Saw a suggestion there to mark the forward reverse rods before removal so it apparently is possible to mix the two up. One test might be to see if the cruise control works in reverse.. as normally it will not.
/ 4300 hst problem #6
/ 4300 hst problem #7
I dont think the 4300 is eHST so not the plugs. Mechanical linkage with position sensors. Different setup.
Most pumps and motors can be reversed by putting in the stator or valve plates in backwards based on the design. Either your linkage is hooked up wrong or the pump went together wrong.
/ 4300 hst problem #8
Sorry to the OP. I didn't realize the 4300 wasn't an eHydro like my 4310. I thought it was nearly the same as my tractor.
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
Volvo EC220EL (A60462)
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A61572)
2025 Kivel Fork...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
2014 John Deere 650K LGP Crawler Tractor Dozer (A61572)
2014 John Deere...
