4300 gear range selection
/ 4300 gear range selection #11
Im thinkin you will get use to your machine soon and wont have trouble with it anymore.Gotta get the new rubbed off !
Good luck.
/ 4300 gear range selection #12
The range lever on 4200, 4300 and 4400 Tractors, starting with the following serial numbers, was changed so that a 4-bar linkage is used instead of the previous single-bar linkage. This gives the operator a more positive feel of engagement when shifting ranges.
LV4200H320262
LV4300H330185
LV4400H340247
LV4200C327124
LV4300C335218
LV4400S344086
LV4300S336146
Kit part number to retrofit older tractors is LVB25019
If I understand JD's numbering system, a tractor with serial number LV4300S436644 would have the new 4-bar system already installed, correct?
I suspect the problem I was having with this is biological/organic, rather than mechanical. /w3tcompact/icons/smile.gif Will know once my tractor is returned and I can try it again.
Thanks,
Bob
2019 F150 (A61306)
2019 F150 (A61306)
2006 International 7400 SFA 6x6 Bucket Truck (A60352)
2006 International...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
Giyi LW45 QA Hydraulic Winch (A60463)
Giyi LW45 QA...
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
