4300 any hidden zerks?
/ 4300 any hidden zerks? #1
jeff408
Bronze Member
Randle WA
JD 4300
I was reading about a newer JD and it had some hidden fittings under some panels or something. Are there any on the 4300 besides the obvious ones?
/ 4300 any hidden zerks? #2
Jeff:
I have a 4200 that is next model down from yours and is essentially identical in every way except HP.
I assume you've checked the manual for zerk locations. If you don't have a manual, you can get one from the dealer in paper or on CD, or you can get the manuals via John Deere Technical Information Bookstore - Home Page
The CD is cheaper and you can print out replacement pages at will. I also got the shop manual, which is helpful in understanding your rig.
My owner's manual shows a zerk for the hydrostatic tranny pedals that isn't there. The zerk was probably on pre-2001 models. The worst one to get to is the brake pedal zerk on the right side by the fuel filter. It's behind a plastic panel and takes a mirror and feel to find it. I wish they would have put an extension tube on it like they did on one underneath near the hydraulic system filter.
An editorial comment, I wish the 420, 430, 460 loaders had the zerks on the lift pin ends like the newer 300 & 400 CX/X loaders do. Getting to some of those zerks is a real PITA.
Thanks for the relpy. I checked the manual and it only shows the tierod ends for the 4wd. But there are 2 more they didnt show for the foot pedals. So hopfully there are no more that I am missing.
/ 4300 any hidden zerks? #4
Service Lubrication shows a number of grease zerks.
A - King Pins
B - Tie Rod Ends
C - Lower Brake Pivot Tubes
D - HST Models: Hydro Pedal Linkage Shaft
E - HST Models: Upper Brake Pedal Tube
In the next section of the manual they also call out the pivot arms on the 3 pt.
/ 4300 any hidden zerks? #5
A - King Pins
B - Tie Rod Ends
C - Lower Brake Pivot Tubes (can't find this one on mine as mentioned above)
E - HST Models: Upper Brake Pedal Tube (PITA to get to)
I forgot about the owner's manual being online, thanks for posting the link for Jeff.
