4300 any hidden zerks?
/ 4300 any hidden zerks? #1
jeff408
Randle WA
JD 4300
I was reading about a newer JD and it had some hidden fittings under some panels or something. Are there any on the 4300 besides the obvious ones?
/ 4300 any hidden zerks? #2
Jeff:
I have a 4200 that is next model down from yours and is essentially identical in every way except HP.
I assume you've checked the manual for zerk locations. If you don't have a manual, you can get one from the dealer in paper or on CD, or you can get the manuals via John Deere Technical Information Bookstore - Home Page
The CD is cheaper and you can print out replacement pages at will. I also got the shop manual, which is helpful in understanding your rig.
My owner's manual shows a zerk for the hydrostatic tranny pedals that isn't there. The zerk was probably on pre-2001 models. The worst one to get to is the brake pedal zerk on the right side by the fuel filter. It's behind a plastic panel and takes a mirror and feel to find it. I wish they would have put an extension tube on it like they did on one underneath near the hydraulic system filter.
An editorial comment, I wish the 420, 430, 460 loaders had the zerks on the lift pin ends like the newer 300 & 400 CX/X loaders do. Getting to some of those zerks is a real PITA.
Thanks for the relpy. I checked the manual and it only shows the tierod ends for the 4wd. But there are 2 more they didnt show for the foot pedals. So hopfully there are no more that I am missing.
/ 4300 any hidden zerks? #4
Service Lubrication shows a number of grease zerks.
A - King Pins
B - Tie Rod Ends
C - Lower Brake Pivot Tubes
D - HST Models: Hydro Pedal Linkage Shaft
E - HST Models: Upper Brake Pedal Tube
In the next section of the manual they also call out the pivot arms on the 3 pt.
/ 4300 any hidden zerks? #5
A - King Pins
B - Tie Rod Ends
C - Lower Brake Pivot Tubes (can't find this one on mine as mentioned above)
E - HST Models: Upper Brake Pedal Tube (PITA to get to)
I forgot about the owner's manual being online, thanks for posting the link for Jeff.
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
Frontier BB5060 (A64126)
Frontier BB5060...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Deere 210G LC (A64126)
