Mowing 430 mower blades
/ 430 mower blades #1
Will4622
Hi, I need a little help so I thought I'd ask here before I break something. I need to sharpen the blades on my mower. Its a JD430 with a 60" deck. Problem is the bolts won't budge and I'm not sure if they're right or left hand threads. I can't budge 'em either way with a 1/2 inch breaker bar and don't want to put the impact on til I know for sure which way they turn. Any help would be appreciated.
Thanks
/ 430 mower blades #2
I had that same tractor and deck many years ago. Also prettty much the same deck on my 755. They are standard right hand thread.
/ 430 mower blades #3
I would advise not using an impact, it could hurt the ball bearings. Instead, add a pipe extension to your breaker bar, 6' if necessary. You will find that the bolts will gradually turn, not snap loose. Use a 6 point impact socket on the bolt and a block of wood between the blades and the deck housing. You might want to invest in 3 new bolts with nice new threads and clean heads when they back out.
/ 430 mower blades
Thanks, That's what I needed to know. I'll try the cheater pipe.
PORTA POTTY (A68842)
2010 Ford Expedition LTD (A64911)
2010 Ford...
2007 JLG 450AJ SERIES II SKYPOWER TELESCOPIC BOOM (A65056)
2007 JLG 450AJ...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
Thompson Water Pump (A66734)
Thompson Water...
2014 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2014 FORD F150...
