430 Loader Level Indicator
/ 430 Loader Level Indicator #21
Anyone happen to have a picture of one of these installed on their loader? I don't have one and am wondering if it is something I should get.
/ 430 Loader Level Indicator #22
I installed my 460 loader myself and the rod fits flush with the tube when level, never cut it. I had always assumed this is the way they were meant to be since every backhoe I have ever used worked the same way.
Come to think of it, our old NH 1720 (7308) loader manual also said to cut it off flush but the dealer delivered it long. I tried using it with a mark on it for a while, but it was too hard to see when it was dark out so I ended up cutting that one too.
Jay
/ 430 Loader Level Indicator #23
Pic on 460 loader. Sorry for low quality, it's dark out.
/ 430 Loader Level Indicator #26
The other ones looked better before I posted them /forums/images/graemlins/blush.gif /forums/images/graemlins/confused.gif
/ 430 Loader Level Indicator #27
Mine fits flush like 4610's. I think you would like it because it helps a lot when plowing and trying to figure out what angle you bucket is at. They are only 25 bucks so it's worth a try. Easy installation too.
/ 430 Loader Level Indicator #28
Mine on my 430 loader is the same as the 460 pictures. The top surface of the indicator rod is painted red, so it's pretty easy to see when you're level.
/ 430 Loader Level Indicator #29
Thanks for the excellent pics. That helps a lot. I think I might have to pick up one of those.
/ 430 Loader Level Indicator #30
This is the same setup that is on my 3130. My instructions said to cut it flush at level. I calibrated mine uo and donw 30 degrees, now I can put the buket in any position.
Dane
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
300 gal Fuel Tank (A66408)
300 gal Fuel Tank...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
16.5' Telescoping Ladder (A66408)
16.5' Telescoping...
County Line 4' 3Pt Mower (A66408)
County Line 4' 3Pt...
