425 rider not charging
/ 425 rider not charging #1
greeny
Chocorua,N.H.
425 rider mower
any ways to check stator/rectifer for operation, or to be able to check regulator
/ 425 rider not charging #3
Not sure what you're working with, but here is a simple test good for most air cooled engines with flywheel mounted alternators; Every one I've seen had a printed circuit regulator mounted somewhere with a three wire flat connector of some sort. The center wire was the battery lead. Should read battery voltage with engine off(some need the key switch on but not all). No voltage indicates a blown fuse or bad connection somewhere. The two outside wires, often yellow, are the stator output and should have somewhere between 26 to 34 volts AC with engine running if the alternator is working. If you test with motor running and have no AC voltage, look for a stator issue. If AC voltage is good and center wire has battery voltage when running but less than 13v, replace the regulator.
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2001 MACK CH613 KILL TRUCK BOBTAIL (A65643)
2001 MACK CH613...
John Deere Starter Wheel Weights (A65640)
John Deere Starter...
