425 on Order
/ 425 on Order
I'm not sleeping tonight!!!! PT will be here at 6am tomorrow morning....yep,
6am! Good by me. I'm already up, dressed, and caffiened by 5:30am every morning. Heh, heh....I may need to call the boss....I'm not feeling too good :p if you know what I mean! Work will drag by tomorrow!
/ 425 on Order #12
Sounds like someone will be calling in sick... :D
/ 425 on Order #13
Take your time and drive slow this morning. You have a whole weekend to bond with your new baby. :)
/ 425 on Order #14
You are going to be very happy with your decision. Did I miss it, or have you already posted the accessories that were purchased with the tractor?
/ 425 on Order #15
Earlier in this thread, he said:
I ordered the LMB, 48" cutter, Forks, mini-hoe, extra attachment plate, and had the turfs swapped to bars.
I'm curious to see if he can stop playing with his new toy long enough to provide us a report of his first impressions... :D
/ 425 on Order #16
Congratulations! I just had a few hours of tractor time this week and I'm delighted with my 425, ... I know that you will be too!
/ 425 on Order #17
JD, how is it going with the big wheel unit. Do you see any negatives to having the big wheels? What projects or tasks have you done with the machine?
/ 425 on Order
You don't know how hard it was to accept the tractor, put it in the barn and then go to work:( . Hurried home and gave it a good inspection checking oil, grease fittings, etc....basically making shure there were no obvious QC items.
Hooked up the brush cutter and AWAY WE GO! Cut a small area (approx 1/4 acre) of overgrown area. It was pleasing (in an odd way) having the cutter in front...I'm used to CUT/brush hogs with the need to alternate between looking forward and checking behind. This experience was NEAT!
Went down by the creek...down a small slope/drop. Cut that area and crawled out. I cut the PTO coming out...so I could lift the cutter 12+" to clear the relatively sharp drop to the low area by the creek. The tractor articulated well...I slowed it down to a crawl and let the hydro pressure turn the wheels and let it crawl itself out. I love the low CG!
Swapped to the mini-hoe and did a quick demo for wife and daughter.
My girls love it! Saw my neighbor with a "WTF?" expression :eek: on his face.
First impressions:
-Wow factor is off the scale.
-Build quality good..think Abrahms tank--There's nothing that feels "light duty".
-Brush cutter is a brute but does not like tall/thick grass unless really slow speed...but I already knew this from using CUTs.
-Learning curve is very shallow---meaning one will quickly adapt to the articulated function....hydro controls are easy to learn.
-For my needs it should be infinetly more useful than any other tractor I could have bought.
Immediate needs:
-The steering wheel knob.
-Extra caps/cover for the connectors when mini-hoe circuit is being used.
Hopefully will post more as I "get into it".
/ 425 on Order
Thanks, You too!
/ 425 on Order #20
Red Zebra said:
Thanks, You too!
Don't forget the coffee cup or drink holder. and the mirror, and extra lights on the upper part of the rops, and reversing wheels is not allowed. :) :) unless you know the consequences
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
LMC 3pt 54' 300 Gal Boom Sprayer (A60462)
LMC 3pt 54' 300...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
(INOP) MASSEY FERGUSON 4710 TRACTOR (A59823)
(INOP) MASSEY...
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
