Mar 4, 2011 / 425 AWS wheel weights #1 G gleward New member Joined Feb 6, 2011 Messages 6 Tractor 425 Does anyone have the width of the wheel spacers needed to use tire chains on a JD 425 AWS tractor?
Mar 4, 2011 / 425 AWS wheel weights #2 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,684 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) Subject is wheel weights, but ask for info on wheel spacers. ?? Spacers Either 1" or maybe 1 1/4" thick. If needed closer than that, I can look to see if I can measure mine. I'm thinking that is the measurement you want when you ask for width.
Mar 8, 2011 / 425 AWS wheel weights #3 P pennwalk Veteran Member Joined Jan 25, 2002 Messages 2,489 Location Lancaster PA Tractor Yanmar 186D I pulled a wheel on my 425 aws. The spacer is 1". It was a good opportunity to hit the grease zerk under there that I have been known to forget. Chris
Mar 8, 2011 / 425 AWS wheel weights Thread Starter #4 OP G gleward New member Joined Feb 6, 2011 Messages 6 Tractor 425 Thanks alot for the information I appreciate the info. Ill end up machining a set for this coming winter. I bought a blade and plan to pick it up next week Thanks again
