4230 transmission issue
/ 4230 transmission issue #1
millgrove99
Allegan, MI
I have an early 70's 4230 and it won't move when in first, third or low reverse. Second, fourth and high reverse gears seem fine. Issue is the same whether in A, B, C or D range. When I let up on the clutch it feels like it wants to move but would stall the engine if the clutch was fully engaged. Have I lost low range? Is it possible to lose just those gears? Is it a possible linkage problem? Fluid level and filter are fine. I am clueless regarding transmissions and would appreciate any suggestions. Thank you for your thoughts.
/ 4230 transmission issue #2
Sounds as if when gear shift lever is in neutral trans is still in a gear. Will tractor try to move with clutch engaged & gear shift levers in neutral?
/ 4230 transmission issue #3
The 1-2, 3-4 and 1R-2R shifts are hydraulic. If it stalls in 1, 3 and 1R, it sounds like the Hi-Low clutch is seized in high range and therefore when low is engaged, high can't disengage. Sound like tractor needs to be split at clutch housing to repair.
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
iDrive TDS-2010H...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
