422 is getting hard to start
   / 422 is getting hard to start #1
MuncyBob
Platinum Member
N Central PA
PT 422
This summer I rebuilt the carb, installed new plugs and fuel filter. Toward the end of the summer I noticed it had to tn over more than usual to start. Now that colder nights are here I am having to turn it over a few times....wait and repeat until finally it starts. She runs fine once running and when the engine is hot she starts right up.
Approaching 500 hours....would a valve adjustment needed be the main cause here?
   / 422 is getting hard to start #2
Rebuilt the carb. Ok, is there any choke mechanism to assist in enriching the mixture or adjustment?
Yes...has manual choke... it works and is used properly.
   / 422 is getting hard to start #4
Yes. Adjust the valves. Mine needed it well before the recommended time. It ran much better after the adjustment.
It's a pain, but do it anyway.
For those that have adjusted the valves themself...any tips other than swear a lot?
   / 422 is getting hard to start #7
The adjusting part is trivially easy if you've previously done a number of valve adjustments on assorted engines.
Turning the crank to just the right position? Not so much...
I've never done a valve adjustment...but seems fairly straight forward from the service manual. Guess I'll be swearing & drinking a lot! :)
   / 422 is getting hard to start #10
here are pictures of how I modified my 425 to make life easier when adjusting valves
2017 JOHN DEERE 26G EXCAVATOR (A52707)
2017 JOHN DEERE...
2011 Kubota ZG222 (A56469)
2011 Kubota ZG222...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
90in Hydraulic Box Blade Tractor Attachment (A55851)
90in Hydraulic Box...
