422 is getting hard to start
   / 422 is getting hard to start #1
MuncyBob
Platinum Member
N Central PA
PT 422
This summer I rebuilt the carb, installed new plugs and fuel filter. Toward the end of the summer I noticed it had to tn over more than usual to start. Now that colder nights are here I am having to turn it over a few times....wait and repeat until finally it starts. She runs fine once running and when the engine is hot she starts right up.
Approaching 500 hours....would a valve adjustment needed be the main cause here?
   / 422 is getting hard to start #2
Rebuilt the carb. Ok, is there any choke mechanism to assist in enriching the mixture or adjustment?
Yes...has manual choke... it works and is used properly.
   / 422 is getting hard to start #4
Yes. Adjust the valves. Mine needed it well before the recommended time. It ran much better after the adjustment.
It's a pain, but do it anyway.
For those that have adjusted the valves themself...any tips other than swear a lot?
   / 422 is getting hard to start #7
The adjusting part is trivially easy if you've previously done a number of valve adjustments on assorted engines.
Turning the crank to just the right position? Not so much...
I've never done a valve adjustment...but seems fairly straight forward from the service manual. Guess I'll be swearing & drinking a lot! :)
   / 422 is getting hard to start #10
here are pictures of how I modified my 425 to make life easier when adjusting valves
PORTABLE SPRAYER (A57192)
PORTABLE SPRAYER...
FORD 3000 TRACTOR (A57192)
FORD 3000 TRACTOR...
(7) 12" X 22# X 171" (2) 12" X 22# X 15.5" I BEAM (A57192)
(7) 12" X 22# X...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
