422 is getting hard to start
/ 422 is getting hard to start #1
MuncyBob
N Central PA
PT 422
This summer I rebuilt the carb, installed new plugs and fuel filter. Toward the end of the summer I noticed it had to tn over more than usual to start. Now that colder nights are here I am having to turn it over a few times....wait and repeat until finally it starts. She runs fine once running and when the engine is hot she starts right up.
Approaching 500 hours....would a valve adjustment needed be the main cause here?
/ 422 is getting hard to start #2
Rebuilt the carb. Ok, is there any choke mechanism to assist in enriching the mixture or adjustment?
Yes...has manual choke... it works and is used properly.
/ 422 is getting hard to start #4
Yes. Adjust the valves. Mine needed it well before the recommended time. It ran much better after the adjustment.
It's a pain, but do it anyway.
For those that have adjusted the valves themself...any tips other than swear a lot?
/ 422 is getting hard to start #7
The adjusting part is trivially easy if you've previously done a number of valve adjustments on assorted engines.
Turning the crank to just the right position? Not so much...
I've never done a valve adjustment...but seems fairly straight forward from the service manual. Guess I'll be swearing & drinking a lot! :)
/ 422 is getting hard to start #10
here are pictures of how I modified my 425 to make life easier when adjusting valves
Interesting....the pics are a bit blurred on my pc but appears you cut out the middle section of the rear tub area and somehow placed screen or mesh over it?
/ 422 is getting hard to start #12
1/8'' aluminum plate with 3/16'' holes fastened with #18 self tapping screws, not shown was the plastic snap cover that covered the hole in the plastic engine shroud. I figured time and effort for modifications was well spent considering how difficult it is to properly adjust the valves
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
Bobcat MT85 (A60462)
2007 Ford F750 Dump (A62613)
2007 Ford F750...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
