4210 eHydro
/ 4210 eHydro #1
OpenSourceEcology
Missouri
LifeTrac
Hi all,
We have a 4210 compact tractor in the shop. Unsure of year. Serial number LV4210H320728.
I have a copy of TM1985 that tells me to check flywheel speed sensor as part of diagnostics. Tractor does not appear to have one. Wiring at connector X25 (hst controller) has different wiring than manual shows.
Can anybody tell me what version of TM1985 I need to get for this tractor?
I see a 2012 version online at therepairmanual but I'm not sure if this is new enough.
Thank you.
/ 4210 eHydro #2
per the John Deere Parts site, your tractor is a 2004, so any manual dated that or later should have the correct info in it
4210 (Hydrostatic Transmission)
2002 Model (Serial No. LV4210H120001-220000)
2003 Model (Serial No. LV4210H220001-320000)
2004 Model (Serial No. LV4210H320001-999999)
/ 4210 eHydro #4
JD parts says the flywheel sensor was no longer used after serial number 320004.
Does your TM1985 have date? I suspect you have an early edition.
/ 4210 eHydro #5
The later tractors used a signal from the alternator to operate the tachometer. Dark green wire #325 goes from alternator to tach.
3ft Metal Star (A65583)
3ft Metal Star...
New Holland 851 Round Baler (A66408)
New Holland 851...
(2) Tractor Wheel Weights (A65640)
(2) Tractor Wheel...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
T/A Manifold Trailer (A64194)
T/A Manifold...
International 806 Wheatland Tractor (A66285)
International 806...
