Mowing 4200 midmount mower HELP
/ 4200 midmount mower HELP #1
Moses589
Chattanooga, TN
John Deere 4200
I have a JD4200 with R1 tires and have put a 60inMMM on. The right side tire bumps the front mower tire and the back tire does not allow the mower to be lifted up all the way. Anyone have and ideas on how to adjust the mower?
/ 4200 midmount mower HELP #2
I have a 4200 with R-4's and a 60 inch MMM and everything fits fine. The yoke and clevis and the draft rod clevis specs have a couple inches of adjustment play which should be used to work around tire size variance. (See page 6 of the operator's manual).
Bill
/ 4200 midmount mower HELP #3
My 60"MMM also hits the right front tire enough to tear up the rubber on the outboard edge during sharp turns. the only reason I can come up with is the position of the front tires. I chose to place mine in the wide position for maximum stability. As for the rear tire problem you're having, I'm running R4's which might be somewhat smaller in dia.
Case 1150G Crawler Dozer (A66285)
Case 1150G Crawler...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 PETERBILT 579...
2201SFL (A64553)
2201SFL (A64553)
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
