Tires 4120 R4 Tires
/ 4120 R4 Tires #1
MT. Sparky
McALlister Montana
Deere 4120
Does anyone know if My 4120 with R4 tires has tubes in the rear tires. I got a front flat:mad: and it does not have a tube. Thanks
/ 4120 R4 Tires #2
Look at the valve stem. If it is the same as the fronts it will be tubeless. On a tubed tire the valve stem would have threads on it with a nut holding thru the hole in the rim.
Or look on your tire most state what type they are.
/ 4120 R4 Tires #3
On tubeless the valve stem is secured in the rim with a hex-head metal nut. Tubes usually have a plastic knurled nut holding the stem.
Fred
/ 4120 R4 Tires #6
4720 - front and rear tubeless.
I put goo in them - have some leaks.
D.
