Tires 4120 R4 Tires
   / 4120 R4 Tires #1
MT. Sparky
McALlister Montana
Deere 4120
Does anyone know if My 4120 with R4 tires has tubes in the rear tires. I got a front flat:mad: and it does not have a tube. Thanks
   / 4120 R4 Tires #2
Look at the valve stem. If it is the same as the fronts it will be tubeless. On a tubed tire the valve stem would have threads on it with a nut holding thru the hole in the rim.
Or look on your tire most state what type they are.
   / 4120 R4 Tires #3
On tubeless the valve stem is secured in the rim with a hex-head metal nut. Tubes usually have a plastic knurled nut holding the stem.
Fred
   / 4120 R4 Tires #6
4720 - front and rear tubeless.
I put goo in them - have some leaks.
D.
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
