Tires 4120 R4 Tires
   / 4120 R4 Tires #1
MT. Sparky
McALlister Montana
Deere 4120
Does anyone know if My 4120 with R4 tires has tubes in the rear tires. I got a front flat:mad: and it does not have a tube. Thanks
   / 4120 R4 Tires #2
Look at the valve stem. If it is the same as the fronts it will be tubeless. On a tubed tire the valve stem would have threads on it with a nut holding thru the hole in the rim.
Or look on your tire most state what type they are.
   / 4120 R4 Tires #3
On tubeless the valve stem is secured in the rim with a hex-head metal nut. Tubes usually have a plastic knurled nut holding the stem.
Fred
   / 4120 R4 Tires #6
4720 - front and rear tubeless.
I put goo in them - have some leaks.
D.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
