4115 owners out there
/ 4115 owners out there #1
Newtogreen
Bronze Member
Harpers Ferry,West Virginia
JD 4115
Hello everyone, I was wondering how many 4115 owners are out there and if they could share any information about their machine like problems they may have had or things I should look out for. Also any stories stories would be interesting. For some background I bought my 4115 two years ago used with 32 hours on it. I haven't had any problems so far except for some minor hydralic leaks on the fel hoses. I only have 145 hrs. on it but my wife uses it for her personal mower I use it for some small plowing and discing,dirt moving,driveway matainence and mowing also. We have 4.6 acres. Thanks Larry
/ 4115 owners out there #2
Mine has 250 hours on it, only problem I had was with the battery. replaced it with an optima and haven't had any problems since. Use mine for mowing, skidding logs, digging and a little of everything.
Thanks Dave for the reply. I see you have a KK 5 ft rotary mower. I assume you are using it behine your 4115. I can purchase a kk 5 ft rotary mower for my tractor for a good price but was a little hesitant because of the size. The rotary cutter was a standard model. Have you had any problems with it being too big for the 4115? Any information you can give me about the combination would be helpful. Thanks Larry
/ 4115 owners out there #4
NTG, Welcome to TBN:D
I have a 4110, your 4115's little brother...your 4115 will pull a 5' standard cutter in most brush easily. You will need front weights or your FEL on to balance things-and if you are cutting super heavy/thick material then you may need to take smaller bites...but it will get the job done.
KUBOTA MOTOR (INOPERABLE) (A68842)
KUBOTA MOTOR...
2021 Kubota U25 (A64911)
2021 Kubota U25...
2019 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2019 CATERPILLAR...
Year: 2011 Make: Hyundai Model: Sonata Vehicle Type: Passenger Car Mileage: 238,660mi Plate: Body (A66738)
Year: 2011 Make...
2008 Sterling L7500 Series T/A Vactor 2115-J6 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
2 Person Metal Pony Dolly (A64912)
2 Person Metal...
