4115 owners out there
/ 4115 owners out there #1
Newtogreen
Harpers Ferry,West Virginia
JD 4115
Hello everyone, I was wondering how many 4115 owners are out there and if they could share any information about their machine like problems they may have had or things I should look out for. Also any stories stories would be interesting. For some background I bought my 4115 two years ago used with 32 hours on it. I haven't had any problems so far except for some minor hydralic leaks on the fel hoses. I only have 145 hrs. on it but my wife uses it for her personal mower I use it for some small plowing and discing,dirt moving,driveway matainence and mowing also. We have 4.6 acres. Thanks Larry
/ 4115 owners out there #2
Mine has 250 hours on it, only problem I had was with the battery. replaced it with an optima and haven't had any problems since. Use mine for mowing, skidding logs, digging and a little of everything.
Thanks Dave for the reply. I see you have a KK 5 ft rotary mower. I assume you are using it behine your 4115. I can purchase a kk 5 ft rotary mower for my tractor for a good price but was a little hesitant because of the size. The rotary cutter was a standard model. Have you had any problems with it being too big for the 4115? Any information you can give me about the combination would be helpful. Thanks Larry
/ 4115 owners out there #4
NTG, Welcome to TBN:D
I have a 4110, your 4115's little brother...your 4115 will pull a 5' standard cutter in most brush easily. You will need front weights or your FEL on to balance things-and if you are cutting super heavy/thick material then you may need to take smaller bites...but it will get the job done.
