4115 just quit need help
/ 4115 just quit need help #1
Newtogreen
Bronze Member
Harpers Ferry,West Virginia
JD 4115
I hope everyone is having a good holiday. Heres my problem. I don't know if this has anything to do with my problem but I will tell you anyway. When I turn on the flashers one bulb doesn't want to light but if you take off the cover the bulb will start to work. I went to cut some wood and all is fine. Driving back to the barn I turned on the flasher and only one bulb was flashing so I said to myself I would fix it later. All of a sudden to tractor just cut off. I have fuel in it. When I turn on the key to on the front and back lights will turn on but the flashers will not work, all I get is a ticking. When I try to start the tractor I just get a single tick. I think it must be a switch that went bad but I don't know where to start. I wonder if the flashers have anything to do with it. Any help would be appreciated. Thanks Larry
Found the problem, the flasher fuse was blown. I never thought a blown flasher fuse would cause the engine not to start but its running now.
/ 4115 just quit need help #3
Have you found out any more about your problem? I have a similar condition with my 4115 when running if I turn on any lights it shoots the fuse and dies. Replace the fuse and turn the lights off and it runs fine. Been doing this for years and I can't seem to find the problem. I would like to use the 4 ways when plowing my neighbors snow.
Sorry for the late reply. No I haven't found out why the fuse blew. I do know that the bulb was bad even though the filaments were good. I haven't put a new bulb in yet. I will let you know if it happens again. Like you I don't use the flashers much. I have had my 4115 since 2007 with out any electrical problems. Larry
2015 PETERBILT 579 (A65643)
2015 PETERBILT 579...
John Deere 230 Disc Harrow (A66285)
John Deere 230...
(3) Tires (A65640)
(3) Tires (A65640)
2021 NEW HOLLAND 185 MANURE SPREADER (A64277)
2021 NEW HOLLAND...
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
