4110 Range shifter broke
/ 4110 Range shifter broke #1
wvurzr
Red Lion PA
JD 4110
My 4110 range shifter broke off inside the tranfer case. Dealer says he will have to split the tractor. 35 hours of labor at 70 bucks an hour...OUCH...Does this sound right
Thanks
/ 4110 Range shifter broke #2
Welcome to TBN:D
I have NEVER heard of that problem before on a 4110 machine...the 4x00 had some problems with it though...
Labor estimate sounds about right though for a split.
/ 4110 Range shifter broke #4
Now would be a good time to buy the repair manual. For $2500 one can do alot of fixing. It can't be that complicated.
Can't imagine how this happened. From shifting mine every time I start it to get the glow plugs to work my shifter feels pretty sloopy.. Must have been hooked on something to break it.
/ 4110 Range shifter broke #6
For this part to break off in the transfer case it must have been a defective part I would think. I hope someone with more knowledge will chime in. Larry
Dealer picked up tractor today.
1750 labor
350 parts
$2100
or trade
2720 15900
62" mower 2700
Hood Guard 200
$18800 - Trade 4110 without 200CX (which i dont know value yet)
or
3320 19350
300CX FEL 4625
Imatch 250
$24,225 - Trade (4110 with 200CX)
How does this pricing sound?
What should I expect for trade?
My 4110 has 388 hours on it. I asked my dealer what could have caused this premature failure, but he did not have an answer.
/ 4110 Range shifter broke #8
In your original post, you mentioned 35 hours at $70. That should have come to $2450. How did it go to $1750? Did they give you a discount?
Thats what they quoted me before seeing it.
dealer thinks bent rear pto shaft caused unnormal pressure in transfer case which lead to shifter breaking.
/ 4110 Range shifter broke #11
Bent PTO shaft? WOW:eek: Seems there may be more to this story than what you have told us...
How did the PTO shaft get bent? Possibly the driveshaft on one of your implements is to long...
/ 4110 Range shifter broke #12
Glad you said that Kenny...
So did they repair the shifter but not the PTO shaft? So it can happen again?
That would completely fit my impression of SYTT (the local JD dealer). Need to make sure you have to come back after all....
wvurzr, I would go get some quotes from Finch in Hanover before settling on what you posted.
Went to Deere Country in Lancaster. They repaired everything. Very good staff and my repair was less than their estimate!!:)
Kennyd The shaft was slightly bent when i purchased it..previous owner with a seeder attachment that was to large for the tractor
Thanks arrabil..will talk with them when i am ready to pull the trigger...
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
Landhonor SGB-11-72W, 72" Grapple Bucket  (A62679)
Landhonor...
8ft Rotary Cutter (A65579)
8ft Rotary Cutter...
Quick Attach Grapple Bucket (A66285)
Quick Attach...
Universal Cattle Squeeze Gate (A64127)
Universal Cattle...
211297 (A62131)
211297 (A62131)
