4110 pinon gear
/ 4110 pinon gear #1
bendeep12
louisiana
Im replacing the front pinon gear in my 2006 4110 4x4. i need to know what is the backlash for it.
/ 4110 pinon gear #2
Don't know if yours is the same as my 2002 model but here are the specs.
Pinion bearing preload - .43 to .51 ft/lbs
Pinion/ ring gear backlash - 0 to .008" (.2 mm)
available pinion shims "A" = .008" (.2 mm)
"B" = .004" (.1 mm)
When I did mine years ago the backlash ended-up OK with the original shims but it's not as critical on this slow-moving vehicle. The preload is more critical, especially if it's not enough and the pinion gear gets a little loose and cocks just a little bit. The last time my diff. went out I just bought the whole chunk new. The ring gear studs are subceptible to breaking in this diff too. Be sure and clean the whole axle housing out if you had a bearing or gear go down badly. I used paint thinner and a blowgun and got it spotless before reassembly. Good luck on the job ....
/ 4110 pinon gear
"B" = .004" (.1 mm)
thanks for the info. this saves me alot of time and headache
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
SKIDED FUEL TANK (A67714)
SKIDED FUEL TANK...
2020 INTERNATIONAL MV607 REEFER (A67714)
2020 INTERNATIONAL...
2014 JCB 190T SKID STEER (A65056)
2014 JCB 190T SKID...
2009 IC Corporation PB105 School Bus (A68183)
2009 IC...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A68183)
1987 Polar 307 SS...
