4110 pinon gear
/ 4110 pinon gear #1
bendeep12
louisiana
Im replacing the front pinon gear in my 2006 4110 4x4. i need to know what is the backlash for it.
/ 4110 pinon gear #2
Don't know if yours is the same as my 2002 model but here are the specs.
Pinion bearing preload - .43 to .51 ft/lbs
Pinion/ ring gear backlash - 0 to .008" (.2 mm)
available pinion shims "A" = .008" (.2 mm)
"B" = .004" (.1 mm)
When I did mine years ago the backlash ended-up OK with the original shims but it's not as critical on this slow-moving vehicle. The preload is more critical, especially if it's not enough and the pinion gear gets a little loose and cocks just a little bit. The last time my diff. went out I just bought the whole chunk new. The ring gear studs are subceptible to breaking in this diff too. Be sure and clean the whole axle housing out if you had a bearing or gear go down badly. I used paint thinner and a blowgun and got it spotless before reassembly. Good luck on the job ....
/ 4110 pinon gear
"B" = .004" (.1 mm)
thanks for the info. this saves me alot of time and headache
RoGator RG1300C (A63688)
RoGator RG1300C...
UNUSED WOLVERINE QUICK COUPLER 1 (A64281)
UNUSED WOLVERINE...
2024 Ford Expedition 4X4 SUV (A61574)
2024 Ford...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
PALLET JACK (A63291)
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
