4105 question
   / 4105 question #1
hyperrust
SC
Kioti DK40, Bobcat CT2025
Hey all. I'm looking at a used 2007 4105 in a few days. Does anyone know if the '07s are appreciably different from the brand new ones? Do they all have quick detach buckets? Thanks!
   / 4105 question #2
No real notable changes that I know of - just the hour meter:laughing:
All should come with the DEERE quick attach bucket - not a skid steer quick attach. It's the difference of the Deere being pins vs levers. There aren't as many attachments for it but it is better than nothing. They will change about equally as fast though.
   / 4105 question #3
I have 2011 and grill is different looks more like 3000 series
Great tractor.
   / 4105 question
Interesting... does that mean I'd be limited as to the grapples I could put on the tractor?
Thanks!
   / 4105 question #5
Thanks!
It does. There will not be nearly as many options, or you will be doing some fabricating. I believe the 4105 runs the 300x loader, not the 400 series loader as well. On the 400 series you have the option for a skid steer quick attach.
   / 4105 question
I went and looked at the tractor today. It's for sale by a guy who buys and sells used equipment. It's a 2007 with only 120 hours. It was owned by an orthopedic surgeon with a hobby farm, and was stored in a barn. He traded it in to the seller for a larger Kubota with a cab.
Apart from some dirt, it almost looks new. The upper lip of the bucket has a small dent that I don't think is compromising its strength significantly (maybe 3 inches wide, one-half to one inch deep at most- not visible in the picture.
One other small(?) issue. If you look at the picture of the 3ph, in the middle of the yellow circle is a piece of wood that's being used as a temporary plug. The previous owner said he had no idea when or how the plug fell out, but he had ordered a new one and had it mailed to the seller, who hasn't replaced it yet. Does anyone know what that plug is for and if it could have harmed anything?
The tractor fired right up, drove fine, loader worked well, loader arms look strait, etc. I'm a tractor novice but saw no obvious problems. I think the price is very good, and it includes an older but working 5ft Bush Hog brand cutter. Any comments, especially on the plug issue?
Thanks.
   / 4105 question #7
Thanks.
Looks like a pretty good machine to me. I would have them fix that one plug - I don't really know what it would be stopping, but would get it fixed. 120 hours is like new too. I'd make him an offer an see where it goes:thumbsup:
   / 4105 question
The seller has the plug and intends to fix it, although I think the fix is just pulling the wood out and putting the plug in! Hopefully I can get a good deal on it. From what I can find it seems good. Not a whole lot of chattering about this model.
   / 4105 question
The seller told me when the PTO was running the hole would seep a little oil. It did not do this today with the makeshift plug in place, although we didn't run it more than a couple minutes with the PTO on. Seller seems like an honest guy, he pointed the missing plug out to me right away. I probably would not have noticed it.
   / 4105 question #10
That may be an oil plug for the PTO shaft then. May want to check the fluid levels in it.
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
2021 Caterpillar 299D3XE Track Loader (A53342)
2021 Caterpillar...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2022 New Holland Workmaster 40 Tractor with Loader (A51573)
2022 New Holland...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
