4105 Fluid leak when running PTO
   / 4105 Fluid leak when running PTO #1
1M05
Dundee, NY
1979 Yanmar YM2000BD 2013 John Deere 4105
When I run the PTO, hydraulic fluid leaks from this hole. If I don't run the PTO, no fluid leaks. Is this a breather? Should something be in this hole?
Thanks
   / 4105 Fluid leak when running PTO #2
Looking at the schematic for the tranny case of the 4105, is it possible that the "cap" key #10 is missing?
Part # M808502
   / 4105 Fluid leak when running PTO #3
Looks higher up to me. Possibly #5 & #6 Plug and O-Ring.
Is the hole threaded?
You will need to top-up your transmission oil.
:wrench:
Part # M808502
I think that is it. Thanks! I just got the tractor with 100 hours on it. I have to figure out if the cap fell out, was never installed, or if the transmission case is building pressure and blew it out.
   / 4105 Fluid leak when running PTO #6
Don't hold your breath Frank...
:wrench:
   / 4105 Fluid leak when running PTO #7
I won't. I know there have been several threads about how not letting the group know about the results of problem solving went. When someone helps me I can't wait to thank them for expanding my knowledge and feel it is a partial payback because then others know the solution.
Frank
   / 4105 Fluid leak when running PTO #8
Totally agree. :thumbsup:
:wrench:
I installed the plug. It just pushes in with your finger. I guess the rubber coating is supposed to hold it in? Ran the brush hog for 4 hours today and about an hour yesterday. No leaks.
   / 4105 Fluid leak when running PTO #10
Good news and better late than never.
Thanks for update.
"...pushes in with your finger." does seem a bit too easy for a sealing plug but :confused3:
2757 (A55787)
2757 (A55787)
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
2026 Quality Steel 5x8 Trailer (A56859)
2026 Quality Steel...
