4105 Fluid leak when running PTO
   / 4105 Fluid leak when running PTO #1
1M05
Member
Dundee, NY
1979 Yanmar YM2000BD 2013 John Deere 4105
When I run the PTO, hydraulic fluid leaks from this hole. If I don't run the PTO, no fluid leaks. Is this a breather? Should something be in this hole?
Thanks
   / 4105 Fluid leak when running PTO #2
Looking at the schematic for the tranny case of the 4105, is it possible that the "cap" key #10 is missing?
Part # M808502
   / 4105 Fluid leak when running PTO #3
Looks higher up to me. Possibly #5 & #6 Plug and O-Ring.
Is the hole threaded?
You will need to top-up your transmission oil.
:wrench:
Part # M808502
I think that is it. Thanks! I just got the tractor with 100 hours on it. I have to figure out if the cap fell out, was never installed, or if the transmission case is building pressure and blew it out.
   / 4105 Fluid leak when running PTO #6
Don't hold your breath Frank...
:wrench:
   / 4105 Fluid leak when running PTO #7
I won't. I know there have been several threads about how not letting the group know about the results of problem solving went. When someone helps me I can't wait to thank them for expanding my knowledge and feel it is a partial payback because then others know the solution.
Frank
   / 4105 Fluid leak when running PTO #8
Totally agree. :thumbsup:
:wrench:
I installed the plug. It just pushes in with your finger. I guess the rubber coating is supposed to hold it in? Ran the brush hog for 4 hours today and about an hour yesterday. No leaks.
   / 4105 Fluid leak when running PTO #10
Good news and better late than never.
Thanks for update.
"...pushes in with your finger." does seem a bit too easy for a sealing plug but :confused3:
TCM FD30T6T Forklift (A55973)
TCM FD30T6T...
Zero Turn Mower (A55853)
Zero Turn Mower...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
Miniature Metal Goat Statue (A55853)
Miniature Metal...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
