4100 Wiring Harness
/ 4100 Wiring Harness #1
4oaksranch
Northern CA
JD4100 Gear
I noticed a couple of electrical connectors, one on each side, running out of the base of the ROPS on my 4100. The connectors are tucked up under the frame at the back of the seat. Both contain two wires. One black and the other red with a yellow stripe (I'm red color blind gang so if I missed it I'm sorry ;-). They are hot with the ignition switch on. Anyone know what they are for?
Thanks -- Chris
/ 4100 Wiring Harness #3
yep, aux work lights.
you will also find an off position on the ignition switch for those lights. [i think it is on the ROAD light setting].
i use one side for my side worklight [points at the mower], the other one runs the fender mounted radio :)
(3) Steel Wheels (A65640)
(3) Steel Wheels...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
90in. Work Bench (A65640)
90in. Work Bench...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
1995 Kiefer Built Gooseneck Trailer (A66285)
1995 Kiefer Built...
