3-Point Hitch 4052R pto issue
/ 4052R pto issue #1
Ljh815
Carbondale il
JD 4500
Hey guys... I have a 4052R with 78 hrs. Didn稚 get much snow this year so it sat a few months unused. Hooked up the tiller today preparing for spring garden, and the pto shaft is not spinning. Pto light on dash comes on, so I assume that eliminates the switch.
Anyone else had this problem?
Any ideas?
/ 4052R pto issue #2
Did you check to see that the PTO/E-PTO lever is in gear?
/ 4052R pto issue #4
If your tractor has the E-PTO option, you will have a shift lever on the right side of the operator station near the 3 point raise/lower lever. The PTO shifter has a big yellow knob on it. Make sure that it’s in position for either standard or E-PTO, and not in between gears.
213111 (A64276)
213111 (A64276)
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
