4052M PROBLEM QUESTION.
/ 4052M PROBLEM QUESTION. #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
New to me tractor. 400 hrs. Today it had a new icon on dash High exhaust temp indicator. I got mixed up thinking it was the regen time..... Dash print out said to run engine at 1500. I did that . It ran for well over an hr and it didn't turn off. The throttle could be turned higher then 1500 but not lower. I putted the tractor home . then I shut it off. Tried to restart . No go... there is the engine low pressure light on dash. Oil levels fine but book says the oil filters is plugged?????. Am hoping then it cools down all will start again.
What do I look for?
So I called a retired JD mechanic . Lives a few minutes away. He came up . Through the dash he looked at the soot amount was 68%. It started for him after cranking for 30 sec Dash asked for 1500 he set it at. 2200 RPM soot amount counted down over say 30 minutes to 15%. where the engine was able to drop below 1500rpm.
As a JD tech he said the regens don't always go off in auto mode so keep an eye on it.
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2006 Flori Off Road Dump Truck DF40 (A65579)
2006 Flori Off...
2021 CATERPILLAR 279D3 LOADER (A64553)
2021 CATERPILLAR...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
