4035 Starting Issues
/ 4035 Starting Issues #21
put air pressure to you fuel tank and watch your fuel lines you will see the fuel line that is leaking. that will be the one you will replaced that should fix that. If you have braided fuel lines they are junk, you need to replace them all with rubber fuel lines I did and I have no more problems.
/ 4035 Starting Issues #22
I skipped replacing with Mahindra sourced lines. Took them to my local hydraulic shop and had the braided replaced with Parker Teflon core SS braided. Last one cost $28 out the door.
/ 4035 Starting Issues #23
Thank you for the reply. I think you hit the nail on the head, time for replacement since they are as you describe 'braided'.
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
Bomag Roller (A63689)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
207274 (A52708)
207274 (A52708)
2008 Ford Mustang Convertible Coupe (A61574)
2008 Ford Mustang...
