4035 Starting Issues
/ 4035 Starting Issues #21
put air pressure to you fuel tank and watch your fuel lines you will see the fuel line that is leaking. that will be the one you will replaced that should fix that. If you have braided fuel lines they are junk, you need to replace them all with rubber fuel lines I did and I have no more problems.
/ 4035 Starting Issues #22
I skipped replacing with Mahindra sourced lines. Took them to my local hydraulic shop and had the braided replaced with Parker Teflon core SS braided. Last one cost $28 out the door.
/ 4035 Starting Issues #23
Thank you for the reply. I think you hit the nail on the head, time for replacement since they are as you describe 'braided'.
2026 Steel Pines Cargo 8.5x20 Enclosed Trailer, VIN#7FWBE2021T1037982 (A61166)
2026 Steel Pines...
2025 Pabreak Hydraulic Vibratory Plate Compactor Skid Steer Attachment (A61567)
2025 Pabreak...
2022 Behnke Trailer (A55973)
2022 Behnke...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
43023 (A59228)
43023 (A59228)
Godwin CD150M Dri-Prime Towable Trash Pump (A61567)
Godwin CD150M...
