4020,only,turns,left
/ 4020,only,turns,left #1
sugargrovefarmer
Sugar Grove
Farmall Super M
Hi Everyone! I,m looking at a 4020 Deere to purchase and it only turns left, Any ideas?
/ 4020,only,turns,left #2
Could be bad o-rings in steering motor under fuel tank or steering valve needs the 4 valves adjusted with a dial indicator.
/ 4020,only,turns,left #3
Yup, that was my first thought too; right half of the steering controller is bypassing. Unless it's leaking, then it's more serious. In either case, not an easy job to remove the dang thing.
//greg//
/ 4020,only,turns,left #5
Those steering valve housings are pretty handy at cracking. If you are looking at purchasing this tractor, you might want to budget a little more than a handful of o-rings to cure the steering problem. Plan for the worst; hope for the best.
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2018 Case TV380 (A64126)
2018 Case TV380...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
John Deere 20' PT Batwing Mower (A64126)
John Deere 20' PT...
LOOK! (A65640)
LOOK! (A65640)
