4020,only,turns,left
/ 4020,only,turns,left #1
sugargrovefarmer
Sugar Grove
Farmall Super M
Hi Everyone! I,m looking at a 4020 Deere to purchase and it only turns left, Any ideas?
/ 4020,only,turns,left #2
Could be bad o-rings in steering motor under fuel tank or steering valve needs the 4 valves adjusted with a dial indicator.
/ 4020,only,turns,left #3
Yup, that was my first thought too; right half of the steering controller is bypassing. Unless it's leaking, then it's more serious. In either case, not an easy job to remove the dang thing.
//greg//
/ 4020,only,turns,left #5
Those steering valve housings are pretty handy at cracking. If you are looking at purchasing this tractor, you might want to budget a little more than a handful of o-rings to cure the steering problem. Plan for the worst; hope for the best.
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
80003CFL (A61568)
80003CFL (A61568)
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61573)
2017 Autocar...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
New Leader MultiApplier Spreader Box (NEW) (A63109)
New Leader...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
